#188806 - 09/11/2003 23:22 Java AAC -> MP3?
Has anybody seen iLoveMP3 before? It seems to be a wrapper around QuickTime for Java which allows you to reencode AAC to MP3 reasonably easily. I've not used it but it does come with source.
#188807 - 10/11/2003 09:25 Re: Java AAC -> MP3? [Re: tman]
Sounds really lossy, no?
#188808 - 10/11/2003 09:32 Re: Java AAC -> MP3? [Re: tonyc]
Depends on how good the decoder is I guess. If the decoder is good then it should be the same as burning to CD and then ripping in theory. Saves you the hassle of burning to CD and then using something like EAC to get a good rip.
#188809 - 10/11/2003 09:36 Re: Java AAC -> MP3? [Re: tman]
Wait, AAC is lossless?
#188810 - 10/11/2003 09:40 Re: Java AAC -> MP3? [Re: tonyc]
Nope. But I'm saying that if the decoder gives you good output then it's the same as decoding it, burning it to CD, ripping it and the reencoding it to MP3. If the decoder is crippled then obviously it won't be a good idea to use it
#188811 - 10/11/2003 10:02 Re: Java AAC -> MP3? [Re: tman]
Ah, I see where you're going.
#188812 - 10/11/2003 11:51 Re: Java AAC -> MP3? [Re: tonyc]
Loc: Los Angeles, CA
why not just itunes -> totalrecorder -> mp3?
#188813 - 10/11/2003 12:20 Re: Java AAC -> MP3? [Re: image]
Because it's free and you get source? I know Total Recorder Standard is only $12 though.
#188814 - 10/11/2003 16:05 Re: Java AAC -> MP3? [Re: tman]
sTeeve
Loc: Decatur, Ga., USA
or use <http://www.blacktree.com/apps/index.html?iTunes-LAME/index.html>
